I just noticed the other day when i cranked up my car (92 Accord EX) the tail light bar was on in the dash. So i got my brother to hold the brakes while i looked and the passenger side and the bar in the window was out. So i said ok i got a blown fuse. That wasnt it so i check the bulbs and switch them around and that wasnt it either. Any ideas what it could be need to get it fixed as soon as possible. Thanks
Taillight Trouble
I had the same problem. Basically due to water entering the tailight housing, the connector which mates to the tailight/brakelight housing gets damaged. For now, make sure a good connection is made to the housing.
Remove the housing cover and you will see a connector with about 10 wires on it connected to a mating connector on the housing. Wiggle it and check again.
The whole wire harness is about $20 to replace.
Tailight gaskets might a good idea to replace.
i had the same problem and just ment that my tail light was burnt out, changed it and all is good
1966 Chevy Nova
1974 Super Beetle
2012 Ford Super Cobra Jet
2004 Honda Element
2004 Honda Ruckus
2003 Honda Ruckus
www.weezoonline.com
www.facebook.com/weezoonline
