Manual antenna mast
    Manual antenna mast
    Noted my mom's 5th gen needs a new mast. It was converted to non-power some time ago. Can the OEM mast (for electric antenna) be used in its place? Didn't Honda sell an OEM manual mast as an option at some point?
    I went to the Majestic Honda website and I no longer see older accessories listed (where I thought I saw such things in the past). The same goes for http://www.ahmotor.com/index.html. I'm sure there are still a few sites left that sell older USDM accessories for CB7/CD7s around (not couting ebay).
    Thanks.
    '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
    EX Lip & Alpine OEM single CD Player. No more useless pocket!
    how about a stero shop? I mean unless it has to be OEM
      Yeah an aftermarket manual mast (which is probably what it has now) would be fine. And it sounds easier to install. Outside of doing the standard removal of the antenna nut and taking it apart where it mounts on the inside and disconnecting the wiring that should be it I'd think.
      No teeth to lineup for a motor and all that. I was just curious if an OEM manual mast
      was sold thru Honda at one point.
