well its about 5 dewgress out and the wind chill is near-10.i let my car run till it was warmed up.ichecked my oil and it is full but for some reason there was like these little foamy bubbles in the oil,they were minascule lil things on the dipstick.it looked like little tiny bubbles in the oil.is that bad?i know it is not water.is thew oil foami9ng for some reason.can i drivew the car like that?thanks
oil problem?
how full is ur oil, is it over the top dot or just under, if its just under then your are fine, if its over some what then its called churning oil...
id not pay attention to it...usually bubles are fine, unless ur ursing a sae 30 then you have a problem.
but its not a big problem...ur oil light doesnt stay on does it?
winters like that, use 5w30..
check oil after the car has been off for 20 minutes....if not u will get a faulse reading sometimesWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
when ur car is on your oil goes through the oil pump, on the valves and everything...and if u check it at that moment u wont get a right reading.
now if u wait 20 mintues and let the car sit and the oil settle you will get a more accurate reading..make sure the surface is levelWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
5w30 has more flow in that weather...use that just to be a little better
if the oil is a little over the crank shaft will churn the oil creating bubles and lessening oil life....
i always am just under the top mark...but yes between the 2 marks and at least in the middle is fine...What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
ITs too damn cold i go back inside and let it warm up outside . I hate it though i have to start my car three times it cuts off three times then stays on the third time. Its just too cold for anything nowadays even to go anywhere literally. I leave the heat on also so when i get in nice and warm I let my whip warm up for 8-10 minutes.
