I don't know what happend with my iacv/ecu. idle perfect , but when rain comes at the middle of my drive, my cars rpm rise from 750 to 950-1100.
whats wrong ?
seems the cooler of my engine result the higher rpm. I notice when heat indicator at dash only 1/4 then idles more up, when 1/2 (normal temperatur) then idles good.
At cold start ? i should wait about 5-10 min before rpm sattle at 750.
resetting ecu couple times, not work.
pls hlp what should i do ? re-map ecu ?
whats wrong ?
