i jsut converted my accord to R134a and its filled up and hold the psi jsut fine and i can feel the compressior kick in but it doesnt blow cold air . how can i tell if the clutch in the compressior is kickin in or not . when i am parted and turn the ac on the rpm's drop like it should . thanks for any help
A/C Problem
Best way to tell is to stick some manifold gages up to the A/C fitting and look at the pressures. With the compressor off, it should be around 75PSI on both high and low side. With the compressor working properly, it should read about 30-50PSI on the low side and about 150-200 on the high side. Check that and get back here with the results.
