Go to turn on my headlights only to find out that they dont turn on only thing that turns on is the driver side corner light and the passenger bumper lamp. If i turn on the driver side signal to make a left it blinks normal, if i put it so it blinks right only the corner lamp will work but at a very fast speed. When i looked at the dash after i turned the lights in the on position i noticed that the right away was faintly illuminated, i checked all the fuses and they seemed fine dont kno what the cause could be can someone please give me some tips. Worst comes to worst its going to the dealer 2morow.
Headlights dont turn on!! need help
Did you check the fuses under the hood too?
Otherwise, it's hard to tell. Nothing I can think of would kill 2 headlights and only one bumper light and corner light. It sounds like a fuse or two but you said you checked that......hmm..........Check the bulbs of all the lights not working. It's simple and stupid but that could be it. It seems like you signal flasher is working correctly so that shouldn't need to be looked at. If you put the high beams on do they work? Eitherway, do you hear the high/low relay clicking? Not sure other than that.
I checked the bulbs they seem to b fine heck they were working perfect yesterday, checked all fuses, if i flash the highs they will work, lows wont work at all and only the blinkers from the drivers side operate as they are suppose to. Ima test a relay from my parents car on mine 2morow didnt do it today since it all happened while i was at my gf's house.
My Cb bad, Cb bright and the cops can kiss my Cb lights - I’m gone!
Frost White Member 13
My Ride
"Girls are like a new car... lease w/ option to buy"
WiredMotorSports
