So I think I have narrowed a turn signal problem to the switch on the column. Hazards work fine all bulbs light up. Fuse is good. Relay is good. Problem is the left blinker flashes extremely fast and dim (only way to get it to stop is pull the fuse or relay). Right side does not blink at all now when I put on the right blinker. So I have the upper and lower column covers off I can see the switch how do I get it off? Chilton's is less than clear. I have done a search I am just wondering if I have to take the wheel off? Swich from the dealer is 56.00 bucks hopefully, like some has mentioned from the search results, it is just gummed up with some dielectric grease (Right I am not that lucky). Any help is appreciated thanks.
Turn Signal Switch ?
