Please look in here then search
What is Vtec?
vtec explained
-Fizzbob7
MAIN RELAY:Hard to start when hot
the main relay (located under the steering column/dash) also controls the fuel pump relay and is very well known for going bad and when hot inside the car, may not allow the fuel pump to come on until it cools for a minute or two......it WILL turn over, but won't fire up.......if this is the case, then you can get a new one from Honda for $70+ (damn) or you can usually get them online for $40 new or rebuilt (just as good, just needs some soldering done to make it work properly)......make sure it's the right one, because most parts stores will sell you the secondary main relay that plugs in the fuse box near the drivers side kick panel.....that one usually gives no problems.....and it's $30, so don't waste your money.....here are some helpful links and pics......
Main Relay
-Fizzbob7
speedo sensor-Speedo wack, S light blinking
Speedo check
how to fix it, detailed instructions!
What is Vtec?
vtec explained
-Fizzbob7
Main Relay
-Fizzbob7
Speedo check
