compression check evaluation!
    Okay my results 6 months ago was:
    1. 195
    2. 195
    3. 195
    4. 195
    Now its:
    1. 175
    2. 175
    3. 175
    4. 175
    Any output on whats going on?? although i DID run a 55 shot of nitrous through it for 1 bottle... ZEX system..
    Could it possibly be a blown headgasket? or leaking headgasket? but then i was thinking if it was the headgasket what would be the odds that each cylinder is leaking the same.... i'm stumped.
    HAN - ZiviCase10287
    Honda-tech - zivicase
    HMT - draztik
    d-series - draztik
    Team Integra - RacinMasonC
    what engine
    was the engine hot or cold
    did you remember to prop the tb open both times
    frankly it seems like you may have just cleaned the engine out
      F22a1 with 178,000 miles on it.... i'm sure before the nitrous some of the carbon was actually helping the compression stay higher and running nitrous through it probably cleaned it out... think so?? engine was hot both times
      HAN - ZiviCase10287
      HMT - draztik
      d-series - draztik
        actually 175 is still dam good .... but like midnight sayid what engine and what s the millage on it also ...
        In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
          all 3 of my accords have compression between 175-180 on all cylinders.... so i see yours as being normal....
          Seattle Silver crew #5
          Member of the Midwest Car Club.
          ..........2004 accord ex v6 - J30A4.......................... 91 accord ex - JDM H22A -- Long gone...
            ok ...your answer to my question came in as i was typing it ...
              seems ok to me, perfect compression is like 178, not even sure how u got 195 without carbon build up. Your fine, just make sure to retard the timing while juicing.
                175 is great. remember f22a cr is 8.8:1. comp tests will read lower numbers than say an h22 would read....at least i think...
                I hate thieves!
                  alright sounds good..... yeah i knew it should be around 178psi like the book says i think... i dunno its 2 am. haha.... and i'm guessing that the nitrous cleared up the carbon build up that was actually building more compression that it should be normal.... glad to see its pretty much perfect!!!!!!!
                  EDIT: yeah i retarded the ignition like 2-3 degrees.... and actually since i sold it 4 months ago.. its still at retarded 2-3 degrees.. haha, i should fix that huh?!
                  HAN - ZiviCase10287
                  HMT - draztik
                  d-series - draztik
                    I just did mine tonight, 180/182/190/190
                    I thought they would all be the same, should I be worried?
                    Lots of carbon on the plugs too!
                    CB7 Tuner Decal MAN
                    CB7 Decal Store[URL=http://www.cb7tuner.com/vbb/forumdisplay.php?f=104]http://www.cb7tuner.com
                    http://jc-graphix.com/index.php
                      No, because they need to read within a certain percentage of eachother...I think like within 10% if I'm not mistaken. Your readings are fine.
                      My Accord History:
                      91 EX 2dr : 91 EX 2dr : 91 LX 4dr : 93 EX 2dr : 86 LXi 2dr : 92 LX 4dr : 92 EX 4dr
                      -Patrick
                        well thats good
                        I gotta do the valve seals, smoking alot but guess not to bad for 155,000
                        CB7 Tuner Decal MAN
