Hey guys...i didnt see anything on the fourms about removing the evaporator and i really would like to know....so if someone can give me a DIY or point me in the right directions...and pictures wouldnt hurt either!!
Removal of Evaporator?
The evaporator is pretty easy to get to. You're going to remove the glove box (damper screw and hinges at bottom). You'll then see alot of black plastic and stuff (not very helpful!). Looking straight on, the blower motor will be on the far right (closet to pass. door.) To the LEFT of that is the evaporator, you're going to have to undo the support straps and 2 connections in the engine bay right under the ABS junk or the emissions black box. Be sure to put the straps back correctly, b/c those seal the gaps and keep the heat/A/C in the system and not leak out at the gaps. I wouldn't mess around w/ the 2 connections if your A/C is still charged!!!
Are you removing your A/C or something? You prob. aren't b/c you're in FL! Good luck and your car is soooo nice, I love it, DX's are great!
Dan
EDIT: Haynes manual will walk you right through almost anything, including that^
Originally posted by 92whiteaccordThanks for the help i already got it out...your right it wasnt that hard.....except for those damn a/c lines...thanks alot for the help tho!
Whats the benefit of removing the evap?ProjectParty.net
Putting an end to the question, "What's going on tonight?"
"This generation has this universal sense of failure" - Kurt D. Cobain
CLUB 1320
My FOR SALE thread...buy my ish
No, here in FL A/C is mandatory, fuck that riding with the windows down BS. I just thought there might be like some kind of HP related gain or something. :dunno:ProjectParty.net
CLUB 1320
Originally posted by wed3kthis post is kinda old but is this heavy?
i wanna remove the whole a/c system, already got the comrpessor, condensor and some of the lines off...
thanks!
Dan
Originally posted by OSAMAI lend u TNT & U blow it out!!
