my car dies on me when im driving. say im just driving then all of a sudden the rpm levels go down and the car dies (idle out). yes i've done a tune-up, checked the air filter, and tranny fluid. i have a automatic 93 lxa. my dad took it to a mechanic and says its the distributor. my question is the distributor really the problem. im just thinking that the mechanic he took it to just wants money from us.
need help asap
When my coil went out, it juts died while i was driving, but if your car starts back up again after its prob not the distributor/coil.
any more specs? does it doit when its hot? cold? after you start it? after running for a long time? some times? all the time?H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
does it constantly all day? every 5mins it shuts down and then takes 5mins to start it back up?
just kinda not enough info, to vauge for us to try and guess..H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
im not really sure b/c i drive no more than 10 min to school, and i drive to work apx 15 min depending on traffic. as i said im just driving for apx 5 min then i idle out and i pull somewhere safe and try to start it back up again. take around 5 minutes to get it to work again, and i get home safely b/c by the time the car broke down im like 2 minutes away.
sounds related to temperature maybe...gets hot enough and shuts off, needs to cool down...what was that accord thing about won't start when its hot out?...or maybe its electrical
my igniter coil was doing that to about 2 weeks ago, sorta it wouldn't die while driving but if i drove the car for a cuple minuts and turned it off it would not let me start it again until it cooled down... your mechanic might be right pertaining to the distro since the igniter coil is in their...Originally posted by ap716my car dies on me when im driving. say im just driving then all of a sudden the rpm levels go down and the car dies (idle out). yes i've done a tune-up, checked the air filter, and tranny fluid. i have a automatic 93 lxa. my dad took it to a mechanic and says its the distributor. my question is the distributor really the problem. im just thinking that the mechanic he took it to just wants money from us.
In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
just mark the top bolt and align it to the valve cover...you can either indent/scrtahc the valve cover or just use chalk.Originally posted by ap716how do i remove the distributor? do i simply unbolt it without having to mark anything?
and then three 12mm bolts and 3 electrical connections...everything should come out.
make sure you have a rag to clean up the oil that is gonna spill out.
