OIL CHANGE PUMP $29
good for changing oil during winter time and a bit less dirty even the misses and the kids can do it
what your thought???
Designed for cars, trucks, boats, lawn mowers, tractors and heavy equipment
Pumps out oil and sludge through dipstick tube
Rotary vacuum pump with 13,500 RPM motor does the job without fuss or annoying mess
Now there?s no need to open engine crankcase drain plug. This pump is lightweight enough for one-hand operation. Draws only 2-1/2 amps from vehicle battery. Includes oil depth wire, 2 flexible suction tubes, vinyl exhaust pipe, vinyl stopper tube, battery clips and instructions. Designed for all 12 volt systems.
