getting feedback on stereo
    anyone know why im gettig so much feedback on my stereo system im running amp and sub and component system and when i hit a bump im hearding the loud feedback wistleing noise, and its low till i step on it and getts louder and louder then it sometimes goes away and sometimes it doesnt and then sometimes it doesnt do it for hours then it just starts up again any clue
    (\__/)
    (O.o )
    (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
    probably ur amp, if it not a really good brade or if is old u can sometimes get that noise
      http://www.cb7tuner.com/vbb/showthread.php?t=27430
        is your power ran down the opposite side of the car as your rcsa? where did you ground?
        FA1
        355
          they are on opposite sides and i grounded one to the back of the seat which i always have and one to the strut mount on top i notice the remote wire was loose and the power cable from the battery was loose i tightend them and the ground on the amp wasnt tightend down good enough its a new alternater ,and ill take it for a ride also my friend said get a ground strap and ground the alternter again to the body but al the ground and everything is all set i might have a little to long of a ground and they where crossing the two grounds and the power cable i seperated them the best i couldand ill get some plastic tubbing around the wires cause it a little bit of a mess with all the wiresbut that was 2 things i found wrong and i have another thig hooked up to the battery and i put that some where else on the pos cable casue they where right on top of each other
          (\__/)
          (O.o )
