i took my evaporator out yesterday because a shop that did a leak test said it was leaking. well, whether it really is or not, i'm tired or poorly performing AC so I am replacing the compressor and evaporator. when i took the evaporator out, it was absolutely filthy. it was filled with a layer of dirt, leaves, etc. anyways, i am still replacing it, but is there a way to prevent this buildup on the evaporator or is this normal for a 13 year old evaporator? i just kind of thought there may be a filter or something that would stop this crap from reaching the evaporator. thanks in advance.
Dirty Evaporator
I'm glad you noticed the problem! All cars (w/ A/C of course!) will get that eventually and it really hinders the velocity of the air from the blower. What you could do is either some foam (like found in an air filter) or just a basic tight net screen to filter out all the large particles. You could just clean that out every 1-2 years or w/e. I'd recommend just on the side facing the blower, the other side of the evap. doesn't really matter too much. Good luck!
Dan
i am waiting for the parts in the mail, i am using all honda parts because i don't want to have to redo this is a year or two. but i am replacing the compressor, evaporator and receiver. and yes it is true you should replace the receiver when you do major work on the AC. i live in FL and i can't go without AC much longer. parts are costing me about $600, but the garage wanted well over $1000 and that's with aftermarket parts.
you know, honda makes a conversion kit from r12 to r134a. there's only two adapters, on goes onto the high side and to the low side connectors. it also comes with pag oil already. it's not that expensive either.
yo man...i did the same thing i took mine to a shop they told me that my evap. was leaking soo i replaced and it next thing u know ice cold man....but now i have a leak on the line to the compressor i think....soo im looking at that today...but u should just replace the evap. first to see what happens along with the dryer...i have a write up on taking out the evap. in the diy section for whoever asked...!
finally finished all the work. a/c is pretty cold. haven't had an extremely hot day to really test it out. new factory evaporator with expansion valve $250, rebuilt compressor $150, o-rings $3, factory receiver/dryer $50, aftermarket condensor fan $60, r-134 and oil $30. not sweating your nuts off in traffice = priceless.
