Ok,
I have a 1990 accord with 155,XXX miles, I just replaced the valve seals and the dam thing still smokes bad, looks like a fogger coming out of my tailpipe. I did a compression test, 180+ all across the cylinders. Now it whent to 180+ withing 3 cranks of the motor. Now im stumped cause things look tword the rings being spent but compression shows different. I know cylinders hold air cause when I did the valve seals the compressor turned on maybe once per cylinder. I am getting a code 12 off my ECU, but that shouldnt have anything to do with the smoke. and Ive only added a quart of oil in a month and a half, which most of that pissed out when my vlave cover gasket wasnt on properly.
Any help would be great!!!!! Im kinda stumperd and even more so after reading 30+ pages of stuff to dee if my symptoms are the same as mine
Thanks guys
Josh
Thanks guys
Josh
