car stereo problem
    car stereo problem
    (Keep in mind this system was running fine for 8 months so far till last night) well I thought my cd player was messed up, apparently not, I tried hooking my stock tape deck up (worked when I first got the car, took it out and never used it again) and the display/sound isn't coming on at all....with my head unit it atleast takes in/spits out cds but has no sound or display. This happened after I hit a bump with my car the other day, I checked my fuse box up front under the hood, they are fine. are there any other fuses I should check? any help would be greatly appreciated
    first this should be posted under the electronics forum............
    2nd...sounds like maybe you knocked your rca cables out the back...because you are getting power..but no sound..check the rear of the deck.
      rca cables...no dude, I didn't hook mine up like that, I used an adapter...anyhow I figured out what it was but thanks anyways
      sorry for wrong forum delete this thread lol
        its the ground wire on your head unit. its touching somthing take the head unit out real quick and check your groud wire. if that dosent do it then i dont know but mine dose that too. fucken car the stario turns on and off. its just a peace of shit
          isnt there a fuse on the back of the deck?
