I tried searching "fan" but of course this forum doesn't permit searching for three-letter words, and for example "radiator" doesn't really describe the issue...
My passenger-side fan squeals like a pig but currently still works. I guess the motor bearing is going bad so I'll replace the fan. I've seen new replacements for about $30 or so, although I wouldn't be opposed to putting in a used one from a junked car either. Honda wants over $150 just for the fan motor.
And if anyone has an experience with the circa $30 aftermarket replacement fan assemblies please speak up. This is a daily driver in stop-and-go traffic --- can't afford to put shit parts in the car.
I noticed today in a parking lot, the driver's side fan not running yet I had the A/C going. Isn't that one in fact referred to as the "A/C fan"?
Shouldn't both fans always run whenever the A/C is on?
Also, when I shut the car off, about a minute later I hear one or both of them run for a few minutes and then stop. That's normal, yes?
OK --- I can temporarily rig some wires from the driver's side fan to the battery to verify if that fan works. If it then does, does that mean I have a relay out? However, for some reason I was under the impression there would be only ONE fan relay, and as stated above the passenger-side fan seems to work fine, except for the squealing of course.
Sounds like I need to replace both fans??
I actually bought a 93 SE in March and I love it. I found it from an older guy in Ft. Myers, Florida who was the second owner. The leather is mint and there is.... NO RUST!!!!! Its the Cashmere Silver Metallic color. I was looking for the Geneva Green SE but they are SUPER hard to find and are almost always junked... The auto trans still works good too. I plan on doing an H22A swap and keeping an automatic. see ya.
