I Am Using A Honda Accord Sm4 92 Model.and Recently Only I Had Spend Moret Then 10k To Renew The Engine And The Suspension.but I Still Having A Jerking Problem Example When Going In Low Gear It Can Be Felled.and The Valve Cover Gasket Got Leaking,i Had Changed The Gasket For 3 Times But Still Got Leaking.........one Of My Mechanic Advised Me It's Becauce Of The Valve Cover Where I Changed To The Carburater Model.pls Advise On Thissssssssss
Jerkingggggggg
probable vacuum leak. you said you had alot of maitenence work done. therefore your mechanic may have neglected to put a vacuum line back in its correct place. common problem with 3rd gen accords. go through all of them and make sure they look "comfertable" in their places. and check for cracks/dry rot. they've sat in teh same spot for 12 years. they want to be where they belong.trust me.
Actually SM1, SM2, and SM4 are just Honda part numbers for parts specific to 4th gen Accords. SV1, SV2, and SV4 are 5th gens, S84 and S87 are 6th gens....etcOriginally posted by clarksterdotcomSM4 is a south pacific model..00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
clarkster... SM4 is the basic chassis code for 90-93 Accords... in all countries. SM2 is for coupes, and SM5 is a wagon. 94-97 Accords are SV4, and 98-02 is S84, and so on... If you look around on your car, you will see SM4 stamped in various places and on parts. anyways, as far as carberated engines, I wouldn't even know where to begin. Honda offers a carberator rebuild kit from the dealer that might help. Personally, I would install a fuel injected manifold and an ECU...Originally posted by clarksterdotcomSM4 is a south pacific model.. yes carbed in 92.. i dont know how to help you though man. most i can do is suggest you to forums that might be local to you..
maybe someone else here might be able to help though. sorry.. good luck with that!
And here I am thinking I was the only one that knew that.Originally posted by xaxis360clarkster... SM4 is the basic chassis code for 90-93 Accords... in all countries. SM2 is for coupes, and SM5 is a wagon. 94-97 Accords are SV4, and 98-02 is S84, and so on... If you look around on your car, you will see SM4 stamped in various places and on parts.
92 Honda Accord LX
95 Honda Civic CX
