91 accord keeps dying need help with codes
    91 honda accord 4door automatic SE silver with black leather, my problem is the car was running and driving fine then she died while i was driving down the street, i tried to restart it with no luck. I went back this morning and it started and she was running and driving fine next thing i know it dies while i'm driving. I sit there for an hour trying to start it every ten min then she starts and i get her home. i shut her off and head to autozone to get a manual and this is what i have so far.
    tranny code 15 defective nm speed sensor
    engine 4 crank angle sensor
    engine 8 TDC position
    engine 15 ignition out put signal
    engine 20 electronic load detector
    Well i just pick up the manual and figured out how to retrive the code, i guess my question is where should i start, and do the tranny and engine code have anything to do with each outher. If anybody has had a similar problem or can see something i can,t please let me know. any help would be great. Thanks Steve
    sounds to me like your distributor swap it out with a friends see if that helps let me know
      check for spark its proabably the distributor or altenator that shit puts things really out of wack but check the distributor first for spark.
        i'll check for spark tomorrow and i'll try the dist. from my outher car. I'll post the results tomorrow nite. Thanks Steve
          yes it was the dist. put a new one it and its fine. How about the code 15 on the tranny what is it and where is it. Is it something i should buy new or from a junk yard. Thanks Steve
