i'm gonna do an engine swap "jdm h22 into a 95prelude si." and i was wondering, the si has the external coil and the h22 don't. how do i go about doing the engine harness? can i use the si harness? i am more use to doing the b series swaps. thanks
any advice??????????
Here's some advice before anyone else gets to it. Try a search. This has been covered many times and should yield a healthy search result. Try it and if you still can't find an answer, let us know.Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
From what i did being that my shit went from external to internal all i did was put a 30amp fuse in there and it cranks right up on the bottom side of the plug it was for my accord though not sure on the preludes it should be the same thing. Busted showed me that way you should try it i think it will work in substitute of the coil.
you can use the H23 dizzy since they are the same for both the USDM external coiled H22/H23.Originally posted by jhondayaaji'm gonna do an engine swap "jdm h22 into a 95prelude si." and i was wondering, the si has the external coil and the h22 don't. how do i go about doing the engine harness? can i use the si harness? i am more use to doing the b series swaps. thanks5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
really??!! i need to check then.Originally posted by PRIMOCB7you can use the H23 dizzy since they are the same for both the USDM external coiled H22/H23.
i used to have the jdm f22b dohc mated to a USDM H23 dizzy since my cb7 was also external coiled. when i lost that motor, and got the jdm H22, i just swapped that dizzy right on. no need to splice any wires whatsover.Originally posted by jhondayaajreally??!! i need to check then.5.6L V8 32V DOHC
i'm gonna try that then.Originally posted by PRIMOCB7i used to have the jdm f22b dohc mated to a USDM H23 dizzy since my cb7 was also external coiled. when i lost that motor, and got the jdm H22, i just swapped that dizzy right on. no need to splice any wires whatsover.
