Rack & Pinion: PLEASE HELP!
    I did everything right, and installed a rebuilt unit today...
    I had to remove my downpipe and skidbar...
    Everything went in great!
    Now to anyone who has done this...
    Does the steering feel tight when its in park or at a complete stop?
    I need to know, because my old unit was kind of loose in park and at a stop.
    Its tighter than usual in park, but on the road its as loose as Ms. Loveless
    I wasn;t paying attention for a pressure release valve or anything... did I overlook that?
    LMK if you think everything is OK.
    My CB7
    I already sent the core back as well..
    My CB7
      Anyone?
      My CB7
        Did you change the power steering fluid?
        1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
        2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
        3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
        4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
        5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
          Yep
          My CB7
            yeah it does...theres no pressure valve either so as long as youre not leaking fluid, you should be fine...i did mine like 2 weeks ago.
            Originally posted by fizzbob7
            Originally posted by ACC0RD22
            So. Cal OUTLAWZ
              come on guys... can we get a DYI?
              http://www.get-gifts-for-free.com/?ref_id=4810
              1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
                I won't do one as it will probably be incorrect...
                I was on it for 6 hours...
                My CB7
                  my diy is up
                  So. Cal OUTLAWZ
                    Hey bro,
                    I am having the same problem it sounds like you were having; play in the steering wheel, and depending on which way I would turn the wheel, it would stay on that side (Honda Tech told me my steering rack is loose). But they wanted $1500 to replace the unit. Fuck that. I'll do it myself!
                    How much trouble is it replacing the power steering rack, if I have the Hanyes manual, and am relatively competent?
                    Did you get the replacement rack from an autoparts store like Advanced auto parts, or Auto Zone?
                    Thanks, I appreciate any help!
                    Daniel
                    Awesome!
                    CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
                      there is a rack guide adjustment. that basically puts drag on the rack, you can try adjusting that.
                        bumpidy bump for a guesstimate about the difficutly of this repair?
                        Daniel
                        Awesome!
                          Has anyone done a manual rack and pinion swap before? I've been thinking about doing that since I don't have any PS anyway.
                          R.I.P. CB7; hello spec-v!
                          Member's Ride
                          FS thread: full part-out
                          Help me with my spec-V fund, buy my stuff!!!
                          Degree of rice and performability are inversely related.
                            are you sure you plugged the 2 pin connector in on the hose?? the green one.
                              This is my guess, also make sure you connected the speed sensor back up correctly, ps lines run to and from it.
