Bad coolant leak...
    Bad coolant leak...
    The other night I was driving, and when I pulled up to a light, all this smoke was coming from under my hood. I pulled into the nearest parking lot and there was a big trail of antifreeze behind me. I want back to check it out today and all the upper hoses seem ok. I started to pour water in and after about half a gallon, it started to gush out. Under the car, it was running down the engine/transmission mating surface. All the hoses I could see were fine. Are there any hoses right in between the engine and transmission? Or does it sound like I cracked my block? I'm gonna get as much of it inspected tomorrow as I can (as in, anything we can do without taking it apart)
    Originally posted by DoctorCipher
    ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
    almost the same problem as me too!mine we never seen gush out though.. still lookin for that daymn leak, i put more coolent in and i havent had a problem for a few days so im not sure whats going on yet.
      if u didn't turn the car off as soon as u saw smoke then yea u could have some problems. most likely a hose u can't c. i had a few coolant issues and they all turned out to be hoses.
      My members ride thread
        Its probably comming from the bypass hose. Its located right underneath the distributor.
        00 Jeep Grand Cherokee 4.7 V8 4X4
        92 Honda Accord LX
        95 Honda Civic CX
          But would that mean my water pump is bad then? Cause otherwise I wouldn't see a reason for there to be a need for water to come out the bypass
            you need to get the car on a lift. there are lots of hoses that flow water through them. It could be a heater hose, an oil cooler hose, the lower radiator hose...
              Originally posted by InvaderTrax
              ... Under the car, it was running down the engine/transmission mating surface. ... Are there any hoses right in between the engine and transmission? ...
              mrhonda's suggestion seems to fit this pretty well. If you remove the distributor you'll see the hose and that area better.
                http://www.92lude.com/forum/index.ph...topic=7710&hl=
                  do a pressure test and on the radiator and ull find out were the problems at....
                  92 accord dx....traded
                  97 accord ex....traded
                  93 civic si ....stolen
                  96 tercel ....sold
                  97 ek hatch b17 ..traded
                  97 civic 4door b16 sold
                  04 tsx traded ...for a honda coupe (top secret)
                    ...you didn't click the link. There's a 2mm hole in my block. That's where the leak is
                      i agree. i need to replace mine cause they are hard as rock. another lovely project.
                      If you're gonna go, go with a smile!
                      Current vehicles: 2006 Pacifica Touring Inferno Red (the Wife's) - 30k
                      1993 Accord EX - optima 'red top' battery, magnaflow exhaust, tinted windows - My $500 ride w/ 217k miles
                      2004 Suzuki GSXR750 - Racetech sus f/r. Dunlop Qualifiers. clear Puig DB screen. my drug - 7500 miles
                        my bad. that blows. hmmm....time for an upgrade? heehe
                          i think my puppy is shot as well, i think im a need to replace the water pump....
                          To have loved and lost is better than to have never loved at all #CB7Life
