Emission...nitrogen Oxides
    ok, have to take my other cb7 thru emissons in march, last Sept. or Oct. it didnt pass due to to much Nitrogen Oxide being present.
    anyone every run into this problem?
    what are some of the things i should look at replacing?
    it has to do with the exhaust part of the emissions, not the fuel, i did research and found that out.
    so far im gona look at and replace if needed:
    o2sensor
    thermal stat (just because its about that time to do so)
    Cat. conver.
    air filter
    any others please add.
    also do u think advancing the timing could have cause me to not pass emissions, i did that like 3 weeks before it had to go thru.
    and what about valves, the guy there told me sone stuff to look at and one of them was valves. the valves do have to be adjust so maybe that caused it.
    NEED RAP BEATS.....
    www.soundclick.com/akcidentaltrakz
    if its NOx your talking about you should be looking at your egr valve.
    egr fills with carbon and over time.
    mine is going up as well...
    Retro!
    Hater
      ok, thanks
      isnt there way to clean it or should i just replace it
      NEED RAP BEATS.....
        some take out the egr valve and clean the carbon but some actually clean out the ports..and some replace it.
        i think cleaning out the ports is a pain in the ass.....
        http://www.cb7tuner.com/vbb/showthre...light=cleaning
        perhaps someone else will reply...with more experiance, someone will.
        Retro!
        Hater
