Hey,
Ok. So my engine is vibrating a hell of a lot. I checked that front motor mount (torque strap) and it's extreamly cracked.
I bought the part OEM from HONDA and I need to know how to replace it (esp. some experience from someone who has done it before).
Btw, you guys think I should make that front mount polyurethane before I put it in?
Thanks guys,
T.T.
Thanks guys,
T.T.
good job buying a genuine honda mount. they last long and vibrate the least... Remove the top and bottom 17mm bolts from the mount. The bottom bolt is tough to get to, so you may need an extension bar to get to it. If you're from the salt belt, I would spray both bolts with penentrating fluid and let them sit for a while. The new rod should go right back in place of the old one. Put the bottom bolt in first, then you may have to >>lightly<< jack the engine forward or backward to get the top bolt in. btw, if the front mount was gone, you've prolly ruined the rear one...
