can someone post a guide on how to replace the window regulator and rubber tracks and all taht good stuff....i dont trust mechanics anymore...especially ones from a place called LOW PRICE Auto Glass....
Just put the window down far enough to get it out. You'll see two bolts on white plastic... That's where the window bolts on (and adjusts... adjusting is a pain.) Loosen those and slip the glass out of the top. Then just remove the regulator (loosen the bolts, look on the new regulator if you must to get an idea where they are.. or get a Chiltons...) Stick the new regulator back in, bolt it down, slide the window in, and bolt it in. Adjust, and you're set...
