just a quick question, can someone let me know the sequence to remove the head bolts ?
cylinder head bolt removal sequence
NO! Do NOT use an impact gun to remove head bolts. They must be loosened in stages (the books tell you how much to turn them on each pass) in the proper sequence. If you recklessly loosen then with an impact gun you risk warping your head. Just use a good breaker bar. If you have to use extensions, make sure they are at least as good as Craftsman. I broke 3 extensions until I used my craftsman one, then all of them came out nice.
Originally posted by SteveBNo idea about the Haynes...but the factory manual says the opposite.
Factory Manual cylinder head removal pages
Originally posted by DoctorCipherNO! Do NOT use an impact gun to remove head bolts. They must be loosened in stages (the books tell you how much to turn them on each pass) in the proper sequence. If you recklessly loosen then with an impact gun you risk warping your head.
If YOU'RE careful then fine... I'm not so sure how many other people can do this. And as far as not following the loosening sequence, think about the head under pressure from all the points that the bolts are at. Honda says to loosen them in that sequence to avoid warpage. Yes I know they are tight... I even had to loosen them with the motor on an engine stand once. Only worked when I put one leg of it against a ceiling support column AND had someone stand on the other end. You'll be fine as long as you have enough muscle to pull a breaker bar worth a damn.
the first time I went through that I went in the wrong sequence and got some of them stuck. The couple times I had to pull it off again after that I was able to do it with the engine on the ground. If you brace it right and have about a 2 1/2' breaker bar, you should have no problems. And incase anyone doesn't want to look at that link, looking into the engine bay (meaning top row = intake side), the sequence would be:
9 5 1 3 7
8 4 2 6 10
(I really shouldn't have that memorized... I've had to take the head off something like 4 times during this project)
thanks for the answers, i have removed heads before i just dont have a car to go get the manual, yea the head bolts are on there good but i do have good tools and breaker bars, i just have to get the timing belt off but i cant get the lower case off , i figured the crank pulley needs to come off but my electric imapct gun for some reason cant get it off and it is 200 ft lb gun, i guess it is just rusted in there, well back to work.. thanks
My winter project on day 1 !!
BUY MY PARTS !!!
Stock hood , front seats , body kit (will seperate)
yea thats how i ended up doing it, i cant believe i spent alot of money on a impact electric gun and it didnt come off, but from what i hear they do have a tendancy of getting stuck.... ah well, got the head off and took off the cam an valve springs today and the valve seals were wasted, got the new ones coming on thursday so thanks again for the help
BUY MY PARTS !!!
