Alright, heres an original problem. I went to turn the heater temp down and it snapped and now turns really easily. I have a 90 EX so the temp control is the rotary knob thing. It still turns, but theres no resistance to it and it doesn't "click" anymore. Whats wrong? What snapped? Now i can't get air beyond the temp that it snapped at (about half way). Does anyone know how I can fix this, or is the dealer the best bet?
WTF! Heater control knob
cable prbly snapped out of the knob, and unless you wanna take apart the dash then you probably should send it to the dealer , unless they charge some ridiculous price because if all that happened was the cable coming out, it should be an easy fix for the dealer.Last edited by thatsitbelowradarSTL; 04-17-2004, 03:06 PM.Originally posted by fizzbob7 i think the "jdm everything" craze is funny........it's the same thing, a fad.......and an overpriced one at that
Originally posted by uncle_el believe it or not, this forum is not about you or your post count. it's about providing relevant information and exchanging it with one another, in order to help build a community. if you don't like that, please leave.
yup, the cable snapped... click the link for more info
http://www.honda.co.uk/owner/AccordManual/index.html
For sure it's the cable and not the knob.. the clicking gives it away, exact same thing happened to me.. wasted my $5 on a new knob that wasnt needed.
Actually, does someone know the name of this cable? I see there are 2 cables coming from the climate control unit in the shop manual, just not sure which one i need to replace...
Aaron
the cable did not snap,i just fixed mine today,take of your entire trim,then take off the climate control box its 4 screws,look at the back and you will see the cable put the end of the cable back on the white plastic piece the cable has a metal ring at the beggining and end of it slide the ring on the post.very easy
I presume I can use a flat head screwdriver to removethe trim pieces, and pry them out? The same damn thing happened to me last night and just when it was startig to warm up outside, the heater knob is stuck at super f-ing hot.Originally posted by 91accord4door
dont take the dash board off just the black trim around the vents,cluster etc.,and the box i fixed mine a 25 mins all said and done trust me,mine just came off the plastic rod.let me nkow how it turns out.
Ok, i brefly read this thread and so i dont know what all answer you fot, here is mine. the knob broke on mine too (90 Accord EX). The new knob cost me $6 from Honda. Now what caused it:
The passenger floor mat sometimes get pushe dup under the ceter dash and keep the "flap" door from moving, you then try to turn the knob and it strips it and breaks it. Keep your fllor mats straight and keep all kids of debrie out of the way.
Also dont keep papre napkins in your glove box. I have worked on MANY 4th gens where peol complaint he A/C/ not blowint good air and coem to find a napkin sucked out of the glove box and covered teh A/C? box intake unde the dash.!!!!!!!!!!!!!!!!!!!
Nope, most of the trim is screwed into place. There is a DIY for painting your trim that details how to remove it. Anyway, I just finished this same repair on my 90 LX and everything works great again. Though if anyone notices a reduced air flow from the vents after they put them back in, pry them out and turn them upside down. The connection between all of the vent directors has to be a specific direction, down I believe, or otherwise blocks air flow. I've got great flow from all the vents now, whereas in the past it was great from the sides, but weak from the center vents.Originally posted by doylna
Hey vmchurch, did you check your knob yet? I've litterally gone through about 10 of those with the two cb7s I've owned. They generally last about a year or two before the plastic knob inside breaks.
However, the cable can snap and it did happen on my 90. Very expensive to fix. Luckily that was when I still worked for a dealer and I got a discount."the J32a2 should be considered one of Honda's masterpieces..." Honda Tuning, July 2006
