hey i am swapping a jdm h22a into my 90 accord, i am not getting fuel to the rail, i tested the wiring and the pump wire clip has power, and i just replaced the fuel relay, my assumption is that the pump is bad, anyone have any other ideas or agree with my assumption on the pump?
not getting fuel???
Have you ever changed the pump since your swap i think maybe its finally took a shit. You may wanna change it out anyway its easy but make sure you almost really low on gas and have something to support the tank because you have to drop the pump from underneath. And be sure to wear goggles theres alot of dirt under there trust me
I had the same problem, altough I did a f20a swap. I had power to pump, relay was tested and good, turned out my pt6 ecu I was gonna use until I got my P39 was shot, and also the ground wire by the thermo housing wasnt grounded enough. I fixed the ground problem, put my pt3 ecu back in and first turn started right up.
Check those 2 things before you rip the pump out, easy to miss the ground and you may have gotten a shitty ecu.CB7 Tuner Decal MAN
CB7 Decal Store[URL=http://www.cb7tuner.com/vbb/forumdisplay.php?f=104]http://www.cb7tuner.com
http://jc-graphix.com/index.php
