cigarete lighter
    cigarete lighter
    cigarete lighter fell apart how the hell do u put it back together??
    My cigarette lighter don't work if you can figure that out too would be great.
    "form follows function."
    Louis Sullivan
      fell apart? can you describe further, or perhaps post pics?
      Seattle Silver crew #5
      Member of the Midwest Car Club.
      ..........2004 accord ex v6 - J30A4.......................... 91 accord ex - JDM H22A -- Long gone...
        this will be vauge, but it screws together from the back. later.
        Avoiding dirt at all costs
          If yours doesnt work, then check the Fuse/Relay
          to see if its good. If its not that, then i guess you got connection problems.
            Yea you need to check you fuses under the hood and in the car, also check to see if anything else in the car is not working like your dome light. If something else is not working then it is probably a fuse. As far as putting one back together it is pretty straight forward it screws together from behind
