I'm trying to check my timing and I can't find the marks. I've got the service terminal jumped and the timing light connected, but when I aim the light at the crank pulley I just can't see anything! Too many belts and junk in the way! So annoying...Where do I find these marks?
Can't find the timing marks!
Alright, I found the timing inspection hole, now what marks am I supposed to line up? I found a picture that basically says to line up the white mark with the pointer. Is that right? To get those two marks to line up I have to pull the distributor all the way clockwise. That just doesn't sound right to me. Help me please!
Ok guys, I went out and tried to get my timing, and after a while of twisting the dizzy back and forth, I noticed a mark on the flywheel. Three lines, to be exact, and the middle line has 15 marked on it. I assume this is the timing mark I am looking for? I rotated the distributor until the mark on the block lined up with the bottom of these three lines. I did 2 pics in MS paint to help show what I mean. These drawings are horribly out of scale, I just did them up to show you what I saw and how I have my distributor adjusted now. The first pic represents those lines I saw and the second represents how I have it set now. Hope they make sens to you.
The 15 degree mark didn't look red to me, it looked like it was black. Anyway, I see some webpages say Accord factory timing is 16-17 degrees. Like picture 2 shows, the pointer on the block is pointing at the bottom of those 3 marks. Since I rotated the distributor counter-clockwise to get it to that position, I assume the timing is now advanced? I took is out on the road after I tightened the distributor down and I didn't hear the slightest bit of pinging. Even with the engine only turning 1500 rpm at full throttle in 5th going up a hill I didn't hear any pnging, so I assume that it is set relatively close to where it should be set. It seems like it might be pulling a bit harder through 1st, 2nd and 3rd and about the same as before through 4th and 5th. I don't know what affect this will have on my somewhat poor fuel economy, but if you really think I should set it back to 15, then I guess I'll go out and bust my knuckles getting that bottom hold-down bolt loose again.
