Clutch Bleeding
    Clutch Bleeding
    Do any one of you guys know how to bleed a clutch i bought a 1993 accord lx and want to bleed my clutch i need pics and instructions......... thank you
    Orignally posted by "graycar"
    http://www.cb7tuner.com/vbb/showthre...leeding+clutch
    "t's a bit of a PITA, but not hard.
    There's a small nut on the top of the slave, open that and you can pump the fluid out. Make sure to put a hose on it so you don't spray it all over your engine bay.
    Close it and get pressure first.
    You have to pump that clutch pedal A LOT.
    Two ideas on that, one is you push it until you feel slight resistence. It's slight, but there. Then just pump between full up and that point.
    The other one is just pump to the floor. That's what I did.
    Knelt on the ground, grabbed the pedal with my hand and pumped it like a rabid dog.
    Once you get pressure and resistence back into the pedal, you can bleed again.
    Get pressure up, open bleeder nut, push pedal down, close nut.
    Pump that wanker again until you get pressure."
      http://www.cb7tuner.com/vbb/showthread.php?t=32791
      or you could use that, pump the pedal a few times in the middle just to get it going, and only pumping you will do after is to make sure its good to go.
        haha your not bleeding it correctly. You have to unscrew the bleeder valve about half a turn or so, put a hose on the nipple that leads into a small cup a brake fluid. Have someone push the clutch pedal down. Tighten the screw back, have the person pull the clutch pedal back up. Repeat till you don't see any air in being pushed into the cup of brake fluid. Make sure the reseviour don't get too low, continue to top it off.
        After about 4 minutes or so of that procedure tighten the bleeder back and have the passenger pump the clutch to test pressure.
        I've found a way to do it by yourself without the use of any extra tools but its difficult to do and difficult to explain.
        This is the response MRX gave me when i made a thread askin about cluthc bleeding.He explains it really well and it worked perfectly for me.It'll take about 4 munites though.
        ILBB
        People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
        Mk3 Supra Member #2
        Originally posted by DarkShadow707
        The world needs to be reset.
