Smoother shifts
    Smoother shifts
    hey guys i bought a 1993 accord lx and my shifter is very hard you guys have any idea of what it could be?
    auto or manny, come on man.
      if its an auto most likely your shift linkage cable has gone bad thats what happened to my car
        Manual...sorry
          Drain the tranny and fill it with either Honda Genuine MTF or Pennzoil Synchromesh.
            Why Does It Do That Same Thing Is Happening To My Tranny
            WTB: edm rear fog, 88-91 ef 4dr
              hard to put into gear
              i have the same problem it is real hard to put into every gear. Ive bleeded it and put MTF in it and did not change anything. im going to try draining the tranny and put MTF in it once it stops fucking raining.
                then tell me if it worked
                  ight im going to drain the tranny tomorrow!
                    use OEM honda manual tranny fluid. they have an additive in there that makes it quieter than the conventional stuff. it will reduce the grinding, if any. all honda techs that i talk to always recommend it.
                    1cor10:31
                    - 92 LX coupe
                    - 96 EX wagon (sold)
                      What did you bleed and put MTF in? You said you are going to drain tranny and put MTF in after it stops raining. So I what did you put MTF in first?
                      I hope not ur clutch
                      BTW,
                      Honda MTF
                      Redline MTF
                      Royal purple SyncroMax
                      all great for honda manual transmissions
                      Post count is not = to experience rating
                      F22B DOHC
