I just did the "rotor over hub" conversion and also replaced BOTH axles with NEW units (not reman'd) and the slight vibrated that orginally existed is now more pronounced.
I doubled check to make sure the axles were seated properly in the int. shaft and in the tranny and they are, plus my axle nuts are torqued to spec.
Has anyone ever had this similar scenario and found that it was caused by something other than the inner cv joints?
I've "heard" other people say things like bearings, ball joints, motor mounts and diff. bearings but I know that ball joints and tie rods cause other symptoms than just a vibration upon accel.
please help. Thank youl.
