I have a 1993 Honda Accord Lx.
My idle does not stay stable. It jumps up and down. Also After I drive or it sits idling for a while the rpms drop slowly and eventually the car dies. Check engine light says that It's an oxygen sensor, but I bought/put a brand new bosch oem replacement. Disconnected the battery terminal and reconnected them again and let it sit for a bit - same story.... Also I replaced the gasket after throttle body and cleaned everyhting thourghly. What's wrong with it and how do i fix it? ...vacuum hoses seem to be fine... Took out ecu fuse to reset it - starts up fine but dies after a few seconds - just shuts off.
Thanks,
-V-
Thanks,
-V-
BOO! Search for rough idle, eratic idle, ect...There are many threads on the problem.
