Hey everyone My homegirl ms mama hooptie2 has a problem with her automatic . Her auto keeps wanting to pull off by itself without her putting her foot on the pedal while its in drive but it keeps wanting to pull off. I checked her tranny fluid its up to par. So what now what should i do because shes buggin me out.
acceleration problems on automatic
Is the throttle cable tense on idle, because...its not supposed to be. The idle screw lets air in the TB. So, you throtle cable is not to be pulling the butterfly at all.
I am guessing thats what it is. 1k is a bit high for idle but not enough to make the car runaway on its own. Does the TB stay open at times. It could probably just need a cleaning.
Originally posted by Ms2.2hoptieAt 1 rpm's going reverse n forward so I reverse dat cables on da tordle body(how eva u spell it) dat my homey H22sparkle touch. After I did dat it didn't do it n e more. only wen I go backwards.
Maybe if used proper english you would get more responses.
and "tordle?" How can you screw up throttle that bad. There's spell check for a reason
Originally posted by do0dfromcaliMaybe if used proper english you would get more responses.
How about next time you decide to pop in a thread and bitch actually contribute something helpful to the problem?
Originally posted by sj960Just outta curiosity, the car moves when u let off the brake pedal?? Aren't all autos supposed to start moving when you let off? Mine does, but it doesnt idle that high, it idles around 700-800rpm...
Sparkle check the idle screw and the throttle cable.
