i have a 90 ex accord 5 spd 4 door
i recently(1 month ago) changed the fuel filter, egr valve and gasket, cleaned iac & throttle body, changed spark plugs and wires, added fuel systems cleaner, seafoamed it............and changed distrubutor about 4 months ago.
the problem is it has a slightly rough idle. At first it was like it was misfiring making popping sound out of the exhaust but then i fixed with when i changed the egr valve. but now i just feel a vibration in the car when its idling
it drives prefectly fine though. Its just when its idling even when i look at the engine its a bit shaky but not alot just like a vibration. all of the motor mounts look ok also. Only thing is i have a cel for o2 sensor could that make it idle the way it does any ideas what it is cause it drives me crazy
