I have spend 2 day researching the setup on the web and I have some question that I'm unsure of the answered and need your input.
THIS IS For a Turbo charged Car so my question is going to be a bit dificult to understand so bear with me.
1. I know there is 2 port on the valve cover one is for a breather valve and the other is an PCV valve. does the breather valve suck in air or flow air out?? Since I heard that Honda PCV uses positive crank crash pressure, so it must drawn in fresh air from the breather valve and then get suck out from the pcv valve to the manifold.
2. I have a breather air filter on the breather valve right now and the fume it release really stink up my whole engine bay and I can't even use the fan with fresh air or else it the smell get inside of the car, is that normal with the breather filter?? can I run a longer hose down to my bumper and have the air filter there so my car does not stink so mutch??
3. should the breather port on the valve cover be connected to either air intake side of the turbo?? since oil might might built up from that would I need a 2nd oil catch tank?? or would there be one oil catch can where I can connect both the breather valve and pcv valve?
4. Oil catch can.. beside being emssion legal, why would you not cap the PVC port on the manifold and have the oil catch can go to a small air filter?? Or The PCV valves do required vacum suction from the manifold to function so that why we stillrun the oil catch out line back to the manifold.
5. With turbocharge engine the pcv port on the manifold will be pressurized with boost since the pcv valve is a one way valve the vcrankcase does not get pressized with boost but what will hapen to the oil catch can?? I see some oil catcg can have a breather air filter on top, what uses does it do when there is vaccum/boost from the manifold. would it create a vaccum/boost leak?? or is it meant to use where you the pcv gas is release to the atmosphere and not going to the manifold?
.... I was just going to buy 2 cheap clear plastic fuel filter and be done with it, but after the research I'm really confused now. Sometime too much knowledge will drive you mad... thank for any help any1 can give..
