i figured this is a technical question. whenever i floor it and my wheels start to spin they kinda shutter or "hop" how can this be fixed? is it a suspension problem? or are my tires too sticky for not enough power at the wheels?
wheel hop
Its a suspension problem... try pumping up the rear tires as high as they go while lowering your front tires alittle to get rid of the problem... have a buddy watch you lauch at the track to see which tire hops and lower than one more than the other... other than that you can lower the front of the car to help with it as well if you have coilovers.Last edited by koolkoreanked; 11-28-2005, 11:39 AM.
Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
try installing an energy supension torque mount insert,it work wonders.
ILBBPeople I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
Like ricky said tires play no part in wheel hop. A strong suspension combination (springs and shocks) play a major part. So do the motor mounts which can all be filled. Even the bushings for the radius rods play a small part. They have traction bars for civics and tegs but none have come out for the accords. Traction bars by themselves virtually eliminate all wheel hop.Knowledge is power...in EVERY sense of the word
Tires themselfs have no play on wheel hop. But tire pressure will help with wheel hop a little. The first time I went to the track with my tires at 45 psi I would wheel hop and spin at 2k... with the pressure down to about 28 I get no wheel hop at a 3k launch and a little at 3500 rpms.
pix!!!!!!!!!!!!?????????????Originally posted by turboh22accordyeap traction bars eliminate tire hop! i got one hehehe
"This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread
koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
what the fuck does AFAIK mean?I see it everywhere
Mk3 Supra Member #2
