ever since i bought my cb9 the e-brake barly worked and i never thought to post about it to see wat it involves to fix it/(tighten it?)...it seems to be a common problem with anycar....i did search, i cant find anything with e brake even in the title name so im sory if it was coverd, a link would be fine too
ebrake barly works
you have to pull the center console (the one covering the e-brake handle) and you will see a cable with a nut attached at the end of it and then of the nut two more cables go back to the brakes.Just tighten the nuts.
The cable thing looks kinda like this: --------I========
"I" is the nut just tighten it,you'll see the two cables pulling.
ILBBPeople I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
