Help My Car Wont Start
    Yesterday i started my car fine, let it wram up cause it was 55 degrees, and took it to school. Never floored it, just drove it above average. after getting home and playing my playstation for ungodly hours (new RPG dragonquest) my father told me to go to wal mart to get some benadryl. Well i get my keys and turn on the starter. All i hear is my starting turning and thats it. My car wont kick on and im pissed cause the texas meet is in 3 weeks and i wanna be there. I tried pushing the throttle to put gas in the cylinders, but no luck. I wanted until this morning and tried again and no prevail. I think it may be the fuel filter, or my plugs are worn. The car has 207000 miles on it and running great, well was running, and everything is stock. And its an f22a4 auto. I also tried starting in park and neutral. Please help
    www.myspace.com/sajunglist
    www.bassdrive.com
    Ok i jsut saw a thread about my CCA (cold cranking amps) ill check that out, but if yall want to add some other info please do jsut in case shit dont work
    www.bassdrive.com
      but the starter turns correct? like the battery has juice? (starting from teh beginning... you never know)
      SOLD!
        kinda da same thing happened to me, car dunt seem to start in cold weather
        for my car, it cranks and goes on for a second, then goes off, while its crankin', car kinda seem to rattle or shake
          Check for spark. Then check for fuel. I had the same problem and it turns out it was my fuel pump. Hope thats not ur problem though cause it could be a real bitch to change that.
          To check and see if you are getting gas just take off that banjo bolt on the fuel rail and check and see if ur fuel pump is pressurizing the system and then if it is check and see if ur getting spark by taking out one of the spark plug wires and then putting a plug in the end and then ground the plug and crank the engine.
            Ok i changed my plugs to ngk iridum, and i checked my fuel pump and all that intake crap. Im getting fuel into my block and everything is connected properly. My attery is fine cause i got it checked, bought a new one and that didnt work either. I believe its my distributor cause i did a spark test and i didnt get any arcs of my plugs. I believe an Oem one costs abotu 200 but i also got an H22 for 500, but thats another stroy and im not so sure aobut the h cause i havent seen it yet. Im goona send it to a shop cause i dont have the necesaries to go about fixing it cause i also heard that if ur distribuaotr os messed up then my timing may be off and thats a whore to do. Well any help would help so give me a clues and info on how to fix my beast
            www.bassdrive.com
