my cars idle is weird. from time to time it will jump from abotu 750 to 1500 and then drop. then jump again and drop. and it will do this alot. what could this be?
normal? or abnormal?
It's either the fast idle valve or the EACV that is causing the idle to fluctuate. Most of the time it is simply that there is a small coolant leak that is lowering the coolant level to below the Fast Idle Valve. My engine started doing it after I put the Vigor throttle body on, which has larger idle circuits. So I had to adjust the Idle screw ALL the way down. Now it still idles around 950, instead of 750, where it should be.Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
