i've been wondering why cluster and climate control lights dont work..i tried to ignore it for a while but its been pissin me off..all my fuses are good and idk what else could fix this..need help
lighting problem..
What about the brightness switch or dimmer switch. Also maybe the bulbs are burnt out. After all they are over ten years old at least.1991 Black Accord Coupe
Sprint Lowering Springs
Neuspeed/Koni Sport Shocks
Suspension Techniques Front and Rear Sway Bar
17" Motegi DP6 with Bridgestone Potenzas
TSX HID Retrofit with 4300K Bulbs
http://www.cardomain.com/id/sthrnba711
Just for kicks- see if your parking lights and tail lights are off as well...I had this problem last winter as it got progressively colder. I'd hit the light switch, but no dash lights, parks or tail, unitl after a delay, or fiddling with the switch. Sometimes the delay would be 5 seconds, and as it got colder- I could have been two minutes.
What I found was many folks saying the grease or lube inside the headlight switch hardened and it was time for a new switch.
Just a thought...
Chris
