Car won't start? help!
    this morning when i got up to turn my car on it would not start...i ckecked the battery, fuel pump fuses relays and everything is ok...could it be my remote start? because ppl have told me that remote start always gives problems in winter time......any ideas on what could it be
    COMMENT MY RIDES!!!!
    91 blue accord ex 4 door automatic
    c'mon ppl help me...i got to get it runnig before saturday
      what you mean remote start, you mean you have an alarm?
      if you think it is you can always jump the starter wire to bypass that portion of the alarm so that you completly bypass the alarms immobilizer.
      are you getting power to your coil?
      Retro!
      Hater
        yes, no power to coil. i think it's my distributer...i have never changed it...thnks
          ok. by "it wont start" ... is it cranking and not starting? or is it not cranking at all?
          breathing is deadly underwater...
            Agreed.
            If it does crank but not turnover, pull one of the spark plug wires out and put it near a ground and see if you're getting spark. If you're not, well then, we've found the problem.
            2DAO (2 Door Accord Owner)
            JDM H22 DOHC 200/161 2.2L
            My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
              it cranks but does not spark..so iguess i have to buy the whole distributer...is it hard to replace?
                dude if no spark then u replace the COIL not the distribitor.
                best way to test it is the way the guy said, take the spark out with the wire and ground the side of it to see if there is a spark.
                Retro!
                Hater
                  i just got done changing my ignition coil and the car is back on the road
                  thanks to accordztech and the other guys for helping me
