Please guys, I desperately need my car back. anything will help.
This weekend I got into a car accident, I rear-ended a SAAB on the highway at like 20mph, she had no damage, but I had a bent hood, hole in the bumper, and my radiator support was a little bent in, so I can't latch down my hood. My radiatior is fine, everything else seems good (no leaking). My car was starting and driving fine until Monday nite, I went to drive my GF home, I inserted the key, and turned, nothing came on, headlights won't work the horn is dead...the car is just totally dead...but 30min later, I come outside and decided to give it another shot...the friggin car turns right on like the champ that it is...I drop her home, and come back, I try to start the car again, and the same thing happens, no JUICE at all...I know its not the battery, because the car started up fine the 2nd time around...could there be a short somewhere? Could it be my KEY or the keyhole? What the hell is the problem? PLEASE, if anyone else has had this problem...please help...
list of my mods: suicide cup holder, arm rest stolen from fold down arm rest in the backseat switched to the front!: custom RUST and DENTS:: removed heat shield...lmao...I hate being a stock noob...don't worry, I'm learning FAST!!!!!
Believe it or not the problems can be that simple. Go check your flux capactitor if you are not satisfied with that possible solution. You probably do not even know how to check battery connections. Do not take your pitiful frustrations out on people who know much more than you ever will. Come on, show me how much more of a dumbass you can be...
