O.E Replacement?
    O.E Replacement?
    Sorry, but another stupid question. I need a new o2 sensor, and I found a good place to get them. I got a 92 accord ex coupe. Anyways, I wanna know what the diff is between universal replacement, and O.E. replacement..
    thanks.
    -A. Swift
    CB7 member number 137
    Black Doubt Crew member #2
    Ebay Whore Club member #5
    -I was at the dentist, breathin' in some nitrous oxide (laughing gas) and all of a sudden..I ran faster!!!
    AIM: boostinswifty38
    alipne 7995 deck, pioneer 400w 4 ch amp, and all the wires for sale..500 obo!
    R/C cars and a heli for sale..2 airbrushes, paints, bodies galore..etc etc..tc3 and xxx buggy for sale..400 for it all! hit me up for details n pics
    The universal is just that, universal...i think it has 4 or 5 wires that you have to cut and hard wire into the factory harness...and most of the time its not as good as the specified OEM 02 senor, plus the OEM will just plug right into the harness, no cutting soldering, ect.
    Jay
    Hittin Switches - Draggin XhaustAlways Under Construction
      doesnt bosch make one that is plug and play into the harness?
      still expensive, but u pay once for many years
      Retro!
      Hater
        Originally posted by SteveB
        Probably.
        Honda certainly doesn't make O2 sensors, so somebody has to.
        _Everybody_ farms those out.
        actually my local honda dealership told me that they had em' in stock for the 4genners. he quoted me at over 200 bucks though , so i went out and purchased a universal bosch (i think?). it's not a direct replacement, you have to do a bit of wiring.. but it's worth the change you save.
          yes, honda sells oem honda o2 sensors and they are absolutely ridiculous in price.. i purchased the bosch sensor for my moms coworker when i changed hers out.. they have little connections to help you splice into the existing harness.. its not "plug and play" though, you DO have to cut off the old o2 sensor.. very easy to do though and around 60 bucks..
            NGK makes Oxy sensors under the NTK name. They are usually pretty reasonably priced. Most of the time we will use Denso units. They are a little more than the Bosch, but we see less early failures from Denso and NTK than with Bosch. For the 4G Accords I can send out the appropriate sensor at $120 (for DX and LX), or $100 (for EX and SE) shipped. Both of those would be Denso, as they are cheaper than the NTK units for these models. If you want to go on the cheap, I can get Bosch Universals shipped out for $75.
            Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
              how do you know when your o2 sensor is going bad?
                Check Engine Light-Code 1: Oxygen Content: O2 sensor, heater, and o2 circuit
                Jay
                  most likely itll throw a code 41 though..
                    I know my o2 sensor is bad, cause the air/fuel mi gauge is pretty much jsut a color show right now..they all light up, then it does this spiral thing, and yeah..just..in consistant? lol..I will replace my o2 when i get a new header..
                    -A. Swift
                      the a/f gauge is supposed to jump around.. when you get on it, it should stay more steady to show how lean/rich the mixture is when you get on it.. when idling and just cruising itll jump around.. you shouldnt need an o2 sensor unless you throw a code for it.. its up to you though..
