Brake fluid
    Brake fluid
    Thinking about doing brake fluid change.
    How much do I need? (Four wheel Disc with ABS)
    Helm Factory Service manual.. no help.
    It only talks about using DOT 3 / DOT 4 brake fluid.
    1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
    2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
    3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
    4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
    5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
    Originally posted by SteveB
    The reason they don't tell you how muh you need is that they don't know, becuase you have to bleed it, and that is a very inexact science. The actual volume of the system is quite small.
    Get two litres to be safe.
    Yes, the actual volume is quite small, but 2 liters? What do you plan to do, bathe in it?
      Well, you don't want to be in a situation where you need 1.1 litres, and only have one. I have no idea of the OP's bleeding skills...if he sucks air to the rear a couple of times....
      Yeah, and although it is nice to use a small amount, sometimes it is nice to have extra for when you need some more, or if you want to bleed extra of the old crap out.
      Just get 2 and you should be good as long as you dont suck in air too many times.
        Thank you for quick response..
        Right now.. I have 0.5L of ARAL DOT 5.1. (boiling point 315C / 599F)
        Freaking expansive.. $22.00 for 0.5L of brake fluid.
        Anyway.. I will order 2 more bottle of brake fluid.
        1L + 0.5L = 1.5L
        ARAL DOT 5.1 / made in Germany
          1L + 0.5L = 1.5L
          If you dont already have that expensive stuff in your car, just use regular stuff from autozone. Unless you are seriously tracking your car, and actually boil your brake fluid, there is no point in upgrading.
            I agree with your comment.
            I should just go with DOT 4.
            ARAL DOT 4 / made in Germany / $18.00 for 0.5L
            Bosch DOT 4 / $10.00 for 1L
              DO NOT use DOT 5 brake fluid unless you have completely flushed and cleansed your system of old DOT 3 or 4 brake fluid. The two will NOT mix because DOT 5 fluid is made of/with silicone...much different composition than 3/4. The only time I would use DOT 5 fluid is if I had just replaced the master cyl, and all lines and calipers, and no fluid had ever been in the system before.
                Good point!
                You are right about DOT 5 which is made of silicone.
                But DOT 5.1 uses same stuff as DOT 3 / 4.
                So 100% competible plus higher boiling point.
                DOT3
                DOT3 brake fluid is the "conventional" brake fluid used in most vehicles. One of the most familiar brands is "Prestone."
                Advantages:
                - DOT3 fluid is inexpensive, and available at most gas stations, department stores, and any auto parts store.
                Disadvantages:
                - DOT3 will damage natural rubber brake seals and should not be used in any car suspected of having natural rubber seals.
                - DOT3 fluid eats paint!
                - DOT3 fluid absorbs water very readily. (This is often referred to as being hydroscopic.) As such, once a container of DOT3 has been opened, it should not be stored for periods much longer than a week before use.
                - Since DOT3 fluid absorbs water, any moisture absorbed by the fluid can encourage corrosion in the brake lines and cylinders.
                DOT4
                DOT4 brake fluid is the brake fluid suggested for use in late model cars. The most familiar brand is "Castrol GT-LMA"
                Advantages:
                - DOT4 fluid is available at most auto parts stores, and at some (but not all) gas stations or department stores.
                - DOT4 fluid does not absorb water as readily as DOT3 fluid.
                - DOT4 fluid has a higher boiling point than DOT3 fluid, making it more suitable for high performance applications where the brake systems are expected to get hot.
                Disadvantages:
                - DOT4 fluid eats paint! Small leaks around the master cylinder will eventually dissolve away the paint on your bodywork in the general vicinity of the leak, and then give rust a chance to attack the body of your car!
                - DOT4 fluid is generally about 50% more expensive than DOT3 fluid.
                - Since DOT4 fluid still absorbs some water, any moisture absorbed by the fluid can encourage corrosion in the brake lines and cylinders.
                DOT5
                DOT5 brake fluid is also known as "silicone" brake fluid.
                Advantages:
                - DOT5 doesn't eat paint.
                DOT5 does not absorb water and may be useful where water absorption is a problem.
                - DOT5 is compatible with all rubber formulations. (See more on this under disadvantages, below.)
                Disadvantages:
                - DOT5 does NOT mix with DOT3 or DOT4. Most reported problems with DOT5 are probably due to some degree of mixing with other fluid types. The best way to convert to DOT5 is to totally rebuild the hydraulic system.
                - Reports of DOT5 causing premature failure of rubber brake parts were more common with early DOT5 formulations. This is thought to be due to improper addition of swelling agents and has been fixed in recent formulations.
                - Since DOT5 does not absorb water, any moisture in the hydraulic system will "puddle" in one place. This can cause localized corrosion in the hydraulics.
                - Careful bleeding is required to get all of the air out of the system. Small bubbles can form in the fluid that will form large bubbles over time. It may be necessary to do a series of bleeds.
                - DOT5 is slightly compressible (giving a very slightly soft pedal), and has a lower boiling point than DOT4.
                - DOT5 is about twice as expensive as DOT4 fluid. It is also difficult to find, generally only available at selected auto parts stores.
                DOT5.1
                DOT5.1 is a relatively new brake fluid that is causing no end of confusion amongst mechanics.
                The DOT could avoid a lot of confusion by giving this new fluid a different designation.
                The 5.1 designation could lead one to believe that it's a modification of silicone-based DOT 5 brake fluid. Calling it 4.1 or 6 might have been more appropriate since it's a glycol-based fluid like the DOT 3 and 4 types, not silicone-based like DOT 5 fluid. (In fact, Spectro is marketing a similar new fluid which they are calling Supreme DOT 4, which seems less confusing.)
                As far as the basic behavior of 5.1 fluids, they are much like "high performance" DOT4 fluids, rather than traditional DOT5 brake fluids.
                Advantages:
                - DOT5.1 provides superior performance over the other brake fluids discussed here. It has a higher boiling point, either dry or wet, than DOT 3 or 4. In fact, its dry boiling point (about 275 degrees C) is almost as high as racing fluid (about 300 degrees C) and 5.1's wet boiling point (about 175 to 200 degrees C) is naturally much higher than racing's (about 145 C).
                - DOT5.1 is said to be compatible with all rubber formulations.
                Disadvantages:
                - DOT5.1 fluids (and Spectro's Supreme DOT4) are non-silicone fluids and will absorb water.
                - DOT5.1 fluids, like DOT3 & DOT4 will eat paint.
                - DOT 5.1 fluids are difficult to find for sale, typically at very few auto parts stores, mostly limited to "speed shops."
                - DOT 5.1 will be more expensive than DOT3 or DOT4, and more difficult to find.
                  There are Autozone's in Seoul?
                  No..
