well i wanna move the battery to the the trunk for a project im gonna be workin on... and since i already have a 4gauge wire running from the bay to the trunk for my amps... can i use that for the battery instead?
Battery Relocation: 4g Cable OK???
just make sure the wire go's strait from the batery in the back to the starter first then from their you can branch to the fuse box ....the starter pulls a lot from ther batery and their cant be anything in between like fuses cause they will blow unless its like a 150 amper (i belive thats what the starter pulls) ...
In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
about running the 4g directly from the battery to the starter... would it be ok to run the 4g to a distribtion block(fuseless), and from there run 8g's to the starter and fusebox?Originally posted by kaponejust make sure the wire go's strait from the batery in the back to the starter first then from their you can branch to the fuse box ....the starter pulls a lot from ther batery and their cant be anything in between like fuses cause they will blow unless its like a 150 amper (i belive thats what the starter pulls) ...
i dont think the bolt on the starter is big enough to fasten two 4g ring terminals, since the initial idea was to run the 4g directly to the starter and from there another to the fusebox.
do you need a sealed box if you have an optima red top battery aren't they dry cell? Do they still put off gas?Originally posted by wrichards2005Make sure you get a sealed battery box. When batteries are charging up, they put out hydrogen gas that you most likely do NOT want to breathe in. I'm sure you know this already though...
Just b/c U post more doesn't mean U know more!
but im going to put a better gauge cus the start is ok but slow
