I was stinking today about hooking up a couple of actuators to the valves and having that run the vavles and let it all be electrical. I have a couple of questions about something like this though. I ran the idea by my step dad who is a thermal dynamics something er ether... and he said it's a good idea and i'm not the first to have that idea. so the question that remains though is why isn't it more popular..why do we still rely on mechanical timing instead of electrical. Everything else is electrical now a days..so why not our cam.
the first thing Mike (my stepdad) said was that the strength needed to over come the spring on the valve would make the actuator kinda big. but what if i got rid of the spring, and had the vavle always closed with no voltage. Then apply 12 volts and it opens. you can increase the strength by using a gear..or vacuum...or magnets or something... i just fail to see how you can't do it with electronics. Windshield wipers are strong and if you use the same idea you could get it dun..maybe... any ideas...
You don't have any of the tunability issues of a mechanical valve system that plague the OEMs, and the parasitic power loss, rotating inertia, windage, and all of the other various little savings from not having a valve train would result in a tremendous power savings. Plus, if you can very cheaply add Variable Cylinder Management, then you probably would save gas too.
