ever since i bought my cb7, the key to trunk didnt work so i would always have to pop open my trunk and i never got around to figuring out what could be the problem, do any of you dudes got this problem?
key does not open trunk
You've got the valet key. Honda has dropped the price on making duplicate keys. I paid only $3 at the local Acura stealership for a copy of mine on an Acura-headed key blank.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
As an alternative solution, there's a steel cable that runs from the lock cylinder to that trunk lid latch mechanism. It's held in by one of those goofy little plastic clips like the ones found in the doors. Last year, my clip broke, and the trunk lid wouldn't open through using the keyhole because the cable popped out every time I turned the key. The only way to open the trunk was with the remote release lever from inside the cabin.
If that's the problem, replacement clips can be had at Autozone or from your dealer, and won't cost more than a few bucks. Took me about 30 minutes to change out.
Either way, it can be a very frustrating problem.I swear, eventually I'll run out of things to break.
I guess I was wrong... I broke it all. Died 10/29/06
I hate that car
