well i was trying to remove my stock f22a1 exhaust manifold earlier myself because i dont feel like paying $150 to get my new HP Design headers installed. i had every bolt removed all the way to the cat but then i noticed a little bracket behind the stock manifold that attaches the manifold to the block i guess. i cant seem to be able to get any wrench behind there to budge the bolts and theres not much room in the space.... do i have to remove my radiator or is there a special trick or tool to use? thanks all input is greatly appreciated.
header removal problem
ok there are 2 Bolts in it one you can barelly get from the top and the other one lay down under the car " make sure its up high enough for these type of things man " look up u should be able to get a socket in there with an extention and a swivel head on it , Just did mine a month ago and thats how I got them out .. NOTE : The Top 'one is a Bitch but it will come out with a socket and a swivel head also ,,,
Good Luck
Hope This Helps
-Sean- Noxidea
